![]() | Home > Technical (L322) > Seat Envy |
Wylie66 Member Since: 10 Jan 2016 Location: Bushey Posts: 67 ![]() ![]() ![]() |
It would appear my 2003 Vogue has had the drivers seat changed unless you informative lot can tell me otherwise!!
Pictures please , and then we can get to work |
Is there any way to tell if this has been done? is it a known weak point? 2003 V8 Vogue in Silver |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
not sure regarding a weak point. but if you put some pictures up, it will help out. it could be that the seat button pack was bought, by request, and not by chassis number. so it was ordered wrongly. -but worked, sort of. im only guessing. dont spend your money yet! |
Not a known weak point at all, but like I said if we could see the seats and the switch pack with the fewer buttons we can tell you more . 2008 MY Supercharged
JohnBoy you maybe onto something. I just had another look and noted that the headrest has no manual adjustment and can't be moved, this now leads me to believe that the switch pack and trim may have been replaced at some point.
Passenger side
i cant comment anymore, as you have i think mid-term range seats, i have early seats. my seats have a third button (for the headrest, up down, and backilt,) and i thought the hse only had the two buttons. if you look on ebay for seat switch packs, you will see the ones im talking about from early cars. and the tiny thrid button. maybe your drivers pack has a fauly knob.
The more i look at it, the more i am convinced the switch pack has been changed.
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6380 ![]() ![]() |
Show us a pic of both the seats themselves. This will help resolve the query Discovery 4 HSE
I wanted to rule out that the seat itself had not been changed.
Bit of further investigation confirms the switch pack has been changed..
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7995 ![]() ![]() ![]() |
I don't think either switch packs look right if I'm honest.
