![]() | Home > In Car Electronics (L322) > Infotainment system crash |
philmc79 Member Since: 10 Sep 2013 Location: Hyde Cheshire Posts: 94 ![]() ![]() ![]() |
I have a 2008 SC and the Infotainment system has on several occasions crashed and the faults are too numerous to mention according to the iid tool, the head unit just keeps cycling on and off, if you press the on off button it flashes about every 5 seconds from the off screen to a blank screen the back to the off screen, if you switch it on and have it set to radio the radio comes on again for about 5 Sec then the unit restarts, i have found by trial and error the only way to get it back to function again as it should is to disconnect the battery leave it for about an hour then reconnect it and it seems to the be ok for about 3 weeks then it starts again.
now you mention it, it seems to happen when it gets cold the night before it happens particularly if it is frosty, you think that could be the fault, would the iid tell me if it is the head unit or a canbus problem? |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8768 ![]() ![]() ![]() |
Quite often the faults on the most are caused by the BT unit in the boot. Problems on the fibre optic network cause all sorts of issues.
