Home > Maintenance & Mods (L322) > Howto Fit Rear Mudflaps to early FFRR
Fitting Rear Mudflaps to L322 First Generation
Promised myself I would do this when I got the car, but never quite got around to it until now. This, on the face of it is a fairly simple procedure, however there are a couple of tricky bits. The instructions that came with my OEM Land Rover rear mudflaps were not all that explanatory, so I thought I would do my own how to. This applies to the early L322's as I believe later models have different style and fittings.
First off, here are the instructions as provided:
All my photos relate to the drivers side rear mudflap (RHD)
1. Here is the mudflap, arrows pointing to the five holes
2. Here are all the nuts, bolts, screws and washers for one side (comes with kit). More on these later.
3. So, let's get to it. Remove the two self tapping screws (1 & 2)
and then for 3, use a pair of pliers to pull out the plastic pin (it will deform)
then use a screwdriver to prise the clip out of the hole.
You don't need these anymore, but you can save them for another project if you want!
4. Now take up your mudflap and fit it to the rear wing, using the two new self tapping
screws for 1 & 2 and one of the nut and bolt sets with washers for 3.
3. With the mudflap loosely fitted, you will see that you have quite a gap
between the side of the mudflap and the rear wing. This is what the holes at 4 and 5 are for.
A leap of faith required now, as you are going to need to drill two holes
into the lower rear wing. Its plastic, so it won't corrode.
I used a bent nail to mark out the drill points, pushing the mudflap up tight
to get it in the right place. The LR instructions seem to indicate you can bend back
the outer edge of the flap to mark and drill, but you might need to dunk it in a
bucket of very hot water to soften it up!
Having marked off, I undid 1 & 2, allowing me to pull the upper part of the
mudguard out of the way to drill.
I drilled pilot holes for 4 and 5, then used an 8mm bit
to drill out a suitably sized hole for fixing
Next you put the two remaining bolts with washers onto the mudguard and push
them through the holes. You are going to need a helper now.
I found that the bolt for 5 was not long enough so I used an 8mm longer bolt
on both sides. Make sure you use a locking nut if you have to do this.
From the photos, it looks like there is plenty of space to get up inside the rear wing
to get the nuts on these bolts, but there isn't. I am fortunate to have skinny arms
that I could just about get a forearm in between the wing, chassis and exhaust
but you might need your helper to do this bit!
Once everything is in place, tight up all round, and you should get a good fit
between mudflap and wing, closing off the gap I mentioned earlier.
Now all that remains is to tidy up, and stand back and admire your handiwork Smile
Yes, I know, I should have cleaned the car before starting on this!
Anyway hope this helps anyone else facing this job. .
Post #35115 7th Nov 2010 4:11pm
DMRR
Excellent write up Smile Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #35119 7th Nov 2010 4:36pm
Thanks Thrasher, its a bit lame I know, compared to some of the stuff we need to do.... .
Post #35121 7th Nov 2010 4:45pm
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
Gents
I am trying to view this guide, but none of the images are loading up... any ideas?
Post #126565 17th Jun 2012 5:10pm
Oh dear my fault. I have changed ISPs and this images were up on that server, not loaded on the site gallery. I'll track them down and reload. Embarassed
They are up now, and in the gallery Smile
http://www.fullfatrr.com/gallery/thumbnails.php?album=510 .
Post #126568 17th Jun 2012 5:17pm
mjdronfield
Thats an excellent write up. Thanks.
There were no rears fitted to mine when I got it, so got the genuine Land Rover ones, same as this thread.
I stared at the instructions, stared at the car, then stared at the mudflaps - and dropped it off at the garage to fit.
A bit chicken I know..........and a bit unlike me, but I'd only had the car a week and didn't want to get merry with the drill and get it wrong.... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #126584 17th Jun 2012 6:52pm
I have bigger holes and washers on the passenger side (where I started/practised) Wink .
Post #126635 17th Jun 2012 10:45pm
