![]() | Home > Technical (L322) > Diff Recall - Can someone just confirm mine is unnafected ? |
td6 vogue Member Since: 31 Dec 2009 Location: essex Posts: 93 ![]() ![]() ![]() |
Best thing is to check with your servicing dealer. When i booked my service this year they mention the diff modifacation to me. They then done whilst car was in for service. no problem at all. |
Fox Member Since: 02 Apr 2010 Location: Essex Posts: 2313 ![]() ![]() |
Best to check with a dealer, but when I got my 55 plate (Nov 2005) it was the 06 model year and they told me the diff spec had been changed so they didn't suffer the same failures as the old ones. |
Avi Member Since: 24 Sep 2010 Location: North West Posts: 309 ![]() ![]() |
Thanks Richard That's what i'm assuming mine will be like as it's an 06MY . I may get wet later and have a crawl underneath. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35800 ![]() ![]() |
if you are lucky enough to have service history invoices it should be marked on that...mines a june 2005 and i had the diff done in july 2007... ... - .- -.
I don;t have them unfortunately. It's been serviced at the same dealer since new, so i'll probably ring them. Is yours the older style, just before the facelift ? |
What year model does your chassis number show Scarey?
@ avi..mines the middle one with the old square front grill ,no dip in the front bumper but with a touch screen nav unit.
That makes sense then, it's a 5. So 2005 model. Diff was supposedly changed on the 6. Just for info, the 3 means RHD auto. ![]() |
is the month of manufacturer on the vin fox? ... - .- -.
Not as such, but you could see where in the sequence it came with the last 5 or 6 digits after that letter A. ie, if it was earlier or later than another 5 model.
Mine's a 36 so that confirms it's a 2006MY, just in case someone had facelifted it and worked out how to fit reversing cameras ![]() |
