Home > Maintenance & Mods (L322) > IID tool errors codes after heavy rain
Balki
Australia
after months on no rain we have 150mm in 2 days, all of a sudden I have multiple faut codes, eas inactive 0x35 ecu error, low ratio fault noise on line and air bag fault something about rhs thorax fault, any way i think they maybe all related to the same thing, I have a water leak abouve the throttle pedal that comes gushing in and probably not helping,
so i have two things i want to find out about, how to find what code 0x35 means and is there a common problem in regards to the water leak
Post #369502 30th Jan 2016 6:23am
From what you describe, none of the faults are real - you're getting water in somewhere which is causing something to think it has a fault.
I'd just clear them and not worry unless they come back again.
.....and fix the leak Whistle
Post #369510 30th Jan 2016 10:05am
miggit
They all sound like BCM faults, so I would suspect that you've also got some water under the passenger seat Shocked I would be checking the sunroof drains are clear...... common fault over here.... Rain that is Wink
It's always a shock to discover that your super dooper all singing and dancing 4x4 is actually aquaphobic Shocked Thud
Rolling with laughter Rolling with laughter Rolling with laughter Yesterday I couldn't spell Engineer... Today I are one!
Post #369529 30th Jan 2016 11:46am
Balki
Australia
thanks for the responses, i will check in the morning
Post #369665 31st Jan 2016 9:24am
