Home > My Range Rover > New L322 owner from Surrey
jonnyboy54321
Hi all
A quick hi from a new L322 owner.
I know a few of the members here as we have common interests across other forums.
Looking forward to learning more about this one, which is:
2007 tdv8 Vogue in Silver, with black leather and burr walnut, 92k miles.
No stranger to LR products as prev had a Disco 1, 3 x disco 2's, and an ill-fated lpg'd P38.
Apologies in advance for the inevitable questions - I do know how to use the search function, which I promise to do first!!!
Am looking for some bits - removable towbar, load liner etc, cheapish private plate so please shout up if you have!!
Cheers
Post #370542 4th Feb 2016 3:37pm
rangeseb
United Kingdom 2006 Range Rover Vogue Td6 Java Black
Welcome to Full Fat! Thumbs Up
Post #370549 4th Feb 2016 4:54pm
Rafterman
United Kingdom 2006 Range Rover Vogue SE 4.2 SC V8 Java Black
Yep welcome and enjoy! The worst thing about being retired is you miss out on all the bank holidays
Post #370580 4th Feb 2016 9:05pm
Croz1
United States 2012 Range Rover Supercharged 5.0 SC V8 Orkney Grey
Welcome!
Post #370816 6th Feb 2016 3:46am
Welcome to the asylum sir Bow down Thumbs Up
Post #370830 6th Feb 2016 10:23am
johnboyairey
Fellow Johnboy, from same county, saying, 'Hi!'
Can't help you with parts, but you can read up here on retrofitting a tow bar...I think your model is the later type, so check this before buying etc. (2006 is the later type?) am I thinking this is correct chaps? Typically people need an armature, that's the main frame bolted underneath, with plug in wiring, and sometimes missing and separately, the choice of the better Westfalia clip-in locking hook, it's a two pice carrier, and drop in hook, though held with a pin and R clip to the armature... Or the slightly chunky looking 'farmers hitch' type which is a sort of plate with adjustable positions for a normal bolt on tow hook. -again all held with a pin and R clip. Both can be permanently fixed with a chunky nyloc nut and bolt. ( with the drop in hook being still removable, and refitted in seconds)
Plenty to read here Johnboy.
Post #370832 6th Feb 2016 10:41am
davidjpowell
United Kingdom 2005 Range Rover Vogue Td6 Zambezi Silver
ayup John Smile
Post #370944 6th Feb 2016 9:08pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
Welcome mate.
What bits are you after for the tow bar?
Post #370947 6th Feb 2016 9:19pm
jonnyboy54321
Hi Paul
Mine has no bar fitted, so the full she-bang. Don't really want a fixed one as I think they spoil the look of the car.
Hi David, fancy seeing you here lol. Fitted your steps yet?
Post #371044 7th Feb 2016 1:31pm
davidjpowell
Hi John
Tried to fit steps. Need more tools are more probably will get it done by someone with more tools...
grrr.
Post #371119 7th Feb 2016 7:02pm
jonnyboy54321
Ah. If only you were closer (and I had two working arms!!) I would have sorted that for you...
Post #371121 7th Feb 2016 7:23pm
davidjpowell
two working arms are probably necessary! I have had some success with my attempt to get music streaming from my phone though. Test bed is working.
Post #371122 7th Feb 2016 7:27pm
Dolphinboy
@newboy John boy
I have an as-new 2006-on tow removable bar (with Key) available. includes electrics etc but needs the ECU (I gave it to a mate Big Cry )
I only bought it for a previous FFRR but sold it before fitting.
PM me if interested.
Post #371233 8th Feb 2016 12:53pm
jonnyboy54321
Dolphinboy, I can't pm you yet as am a new member Sad
Very interested.
The only thing i can think is if you pm your email addy/phone number to member davidjpowell who is a contact of mine
Post #371381 9th Feb 2016 10:19am
