![]() | Home > Off Topic > Anyone work in the compressed gas industry? |
Big Boy R44ROV Member Since: 14 Nov 2011 Location: Chadderton, Oldham Posts: 556 ![]() ![]() |
Don't work in the Compressed gas industry, but I am a Consultant health and safety specialist in nuclear. Obvious questions are what gas are you looking to compress / ship? quantities, pressures, destinations, and the gas' reactivity / stability toward pressure, temperature.metals, substances. Does it change from gas to liquid / vice versa under pressure or temperature. These and many more will determine the type of pressure vessel required. As will the safety requirements of the shipping and destination partners. As an example, a large O2 cylinder of the type supplied by BOC are normally pressurised at 230 Bar ! 1Bar=14.7 PSI. A potential missile if damaged, and i've seen the destruction on can cause. |
Benfelrr Member Since: 27 May 2012 Location: Wiltshire Posts: 301 ![]() ![]() ![]() |
I'll PM you if that is OK. 2011 Range Rover Vogue 4.4 TDV8
By all means! |
Your shipping your farts abroad aren't you!!
Ian c2 Member Since: 19 May 2015 Location: Socal Posts: 217 ![]() ![]() ![]() |
Where in the world will you be shipping to ?
Yes Kingpleb haha youve busted me!
55palfers Member Since: 26 Aug 2014 Location: Solihull Posts: 113 ![]() ![]() ![]() |
I have worked for AGA Gas AB and then Air Products for many years.
