Home > Technical (L322) > Fuel Burning Heater - Fuses |
J evro Member Since: 31 Aug 2014 Location: Kent Posts: 539 |
Hi, have you looked on the inside of fuse cover there's a list there on mine |
7th Feb 2016 6:53pm |
Markbhai Member Since: 05 Jul 2015 Location: bradford Posts: 20 |
HI
8th Feb 2016 11:38am |
Check fuse 19 |
8th Feb 2016 6:11pm |
JST Member Since: 12 Dec 2013 Location: Somerset Posts: 428 |
just digging up an old thread. have a 12plate L322.
22nd Dec 2018 9:15pm |
have also read this, https://www.fullfatrr.com/forum/topic46437.html but i t seems inconclusive for the L322 with various different methods discussed/shown. Cheers
22nd Dec 2018 9:17pm |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1458 |
I just disconnected the receiver in the offside boot panel, waited 10 seconds, reconnected, press the off button AFTER 2 seconds but before 6 seconds, hold the button for at least 1 second, worked 1st time. BMW i3 Electric Car
23rd Dec 2018 5:53am |
Sorted now, thank you. ONly slight difference was the remote unit for the Webasto on my 12plate is right next to the fuse box, not behind it. Cheers
23rd Dec 2018 11:16am |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4219 |
My remote just flashes red for a few seconds then stops. What is the definitive way to pair it to work properly on MY2011.
28th Sep 2019 12:41pm |
Ignore me. Found in wiki 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
28th Sep 2019 12:47pm |
What does the receiver look like and which wire did you unplug? 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" New Defender D300 90 on order so "Rory" will be going to a new home....! 1974 Series 3 Lightweight = "Millie" My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
29th Sep 2019 9:00am |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1193 |
The info is in the WM in the Wiki.
29th Sep 2019 12:14pm |
Yep! Know about fuse 16 but someone mentioned unplugging the receiver which I assume is a wire feed into a unit... 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
29th Sep 2019 1:29pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3192 |
It is the power feed to the receiver. Just unplugs and is pretty obvious when you look at it. Certainly in the earlier models it is just a little awkward to get to as it is tucked in behind some other bits.. John
29th Sep 2019 2:05pm |
OK, thanks. New fob battery to be fitted first then will try again to pair it.... 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
29th Sep 2019 4:03pm |
