![]() | Home > General > Interior Door Badge Replacement |
| pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865
they look nice dan as you say they look better with the cream trim "RANGEISM WILL NOT BE TOLERATED"
| T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936
Do they fit in the later models? 08MY for example Ian |
| dan_uk_1984 Member Since: 12 Nov 2008 Location: Bude, Cornwall Posts: 4014
I "think" they were from an 08 or there abouts - I can't be sure without Microcat. If you have a similar badge there then yes they will fit - you may have to cut the tag off the black badge as I did. Or it may fit in the same hole - either way it should be OK. You can get them in green too which would have been my preference if the car didn't already have black badges. What I want is the Range Rover badges from the Evoque - but that's a different story for a different thread for a different day!
Thank-you dan |
| Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2951
If i order 4, will they fit both left and right/front and rear? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
| M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325
Dan, where are the green ones available from? 2006 Mercedes CLS
They're on Microcat (dont have it installed on this laptop yet) look at the door fittings and you'll see them. Dan
Green badge part #: EKA500060WYY £4.50 from Britcar: http://www.brit-car.co.uk/product.php?xProd=143902
Oooooohhhhh!
Yup, Like I said, on ours the tag points down, on these it points to the right - so you'll have to cut this off for it to fit and hold the badge in place with a small blob of silicone sealant for easy future removal. I think it looks great with the wood door caps, it finishes the door off nicely. I considered changing to the later door cards, but actually prefer mine now. D
Ordered, I'll get some pics when they're on |
| GregP Member Since: 11 Dec 2010 Location: Exmouth Posts: 1084
Do they fit 2002 HSE models. Mine seem to have just a cream coloured rubber badge saying "airbag" on it.
So yes, they will replace your badge, with the caveat I gave a couple of posts up.
Thanks Dan
| All times are GMT |
