![]() | Home > In Car Electronics (L322) > intermittent 12v sockets? |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
In the 2002 -2005 cars they are on all the time... so if your car falls in to this age bracket it is most likely rust |
jonnyboy54321 Member Since: 29 Jan 2016 Location: surrey Posts: 380 ![]() ![]() |
Mine is the '07 facelift. Hmm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8095 ![]() ![]() ![]() |
They will either be permanently live - or on whenever the ignition is on.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35806 ![]() ![]() |
the one in the boot should be permanently live, the others should be ignition live..
agreed, usb seems the way to go as most accessories can run on that ...maybe have one ciggy socket for heavy duty stuff like tyre inflaters etc.. ... - .- -.
I for one don't, although I have given up the weed, but I stopped using the built in lighters years ago, after it catapulted its' self out the socket and on to the floor, in my MGB GT V8, in the dark, I fumbled around trying to find it........ I did........ but the wrong end...... ![]() ![]() ![]() ![]() The problem with finding an alternative socket and plug, is, because of the high drain that some items put the system it would still need to be fairly bulky in design, and it would still need to be pillock proof..... so it would need to be either another round plug affair or something along the lines of a power plug (domestic 3 pin) at which stage it starts to get bigger. The biggest single problem is the system is DC power, and because of that it can only be connected in one way.......... Durite make an aux plug and socket that is for accessories, but it's still bulky (1/3 smaller) and will only handle 16 Amps, so no real gain there ![]() The main reason that the sockets don't work well is corrosion on the positive terminal at the bottom of the socket.. some one needs to invent a cleaner ![]() Inventor of the 'Guide-o-Matic automatic wheel alignment tool' Former long term L322 owner, Up/Down graded to a Classic Tractor! |
I can't find a purpose built cleaner, but, something like this should knock off most of the corrosion and negate the need to remove the socket, possibly use in conjunction with a vacuum cleaner |
The plot thickens with this one.
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3270 ![]() ![]() ![]() |
Re cleaner : http://www.halfords.com/motoring/engine-oi...aner-400ml
ironhorse Member Since: 13 Dec 2013 Location: birmingham Posts: 355 ![]() ![]() ![]() |
i thought the socket fuses and relay are in the right hand side of the boot(might be wrong) worth checking i think ![]() nige |
Relay? I wasn't aware there was one in the loop, so to speak.
