Home > Maintenance & Mods (L322) > Faults galore!
Andy
Faults galore!
Bimbling along the other day, the dash suddenly lit up like a Christmas tree. Susp inactive flashed up then HDC inactive. Then the car slowed like the brakes had come on
I checked using IID tool and it says right wheel abs sensor open circuit. The car then drove normally once the faults were cleared. However, stopping the car and restarting it a few minutes later brought the faults back with avengance. The brakes came on again and when I pressed the brake pedal I could hear and feel all kinds of weird noises and vibrations under the pedal. Felt like ABS activation.
I can't see any worn wiring to the ABS sensor so I assume it's the sensor itself. Anyone else had this?
Post #428223 18th Feb 2017 12:06pm
Jambo
United Kingdom 2012 Range Rover Westminster TDV8 Santorini Black
Had this happen on my Disco 3 on the M6 - really unnerving! From memory the car had just under 100,000 miles on it.
Spoke to a technical guy on the D3 forum who straight away said sounds like a wheel bearing. Took it to local specialist LR garage who said won't be wheel bearing as they'd never had one go on a D3. Test drove it then checked the wheels and then decided it was a wheel bearing!
The way it was explained was that as a lot of the control systems are interrelated, once something goes wrong it cascades through the system triggering other warning lights, even though there isn't a problem with those particular parts of the car.
Hope you get it fixed soon.
Post #428226 18th Feb 2017 12:24pm
miggit
Whistle Sounds like a typical Range Rover.... lacks the correct words for the screen of doom so it just throws up half a dozen major faults to grab your attention... bit like HDC Inactive and EAS Inactive normally means the battery is low and needs charging Shocked Yesterday I couldn't spell Engineer... Today I are one!
Inventor of the 'Guide-o-Matic automatic wheel alignment tool'
Former long term L322 owner, Up/Down graded to a Classic Tractor!
Post #428233 18th Feb 2017 12:51pm
b348xyx
United Kingdom 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
hopefully just an ABS sensor but mine turned out to be ABS ECU Module.
see this post.
http://www.fullfatrr.com/forum/topic40836.html 2003 Range Rover 4.4 Litre V8 - Adriatic blue
2003 Range Rover 4.4 Litre V8 -Maintenance History Click Here = http://www.fullfatrr.com/forum/topic39687.html
Post #428251 18th Feb 2017 3:34pm
holidaychicken
I had all those faults after going through a large puddle which I put down to the cheap $hitpart ABS sensors I bought , I took them out and cleaned them and has been ok since.
The only other reason I could think of was earlier that day it had its MOT and had been on a ramp with its wheels hanging down which may have upset the height sensors. I kept clearing the faults and driving it and eventually it stopped putting the brakes on.
Post #428318 19th Feb 2017 1:49am
