Home > Maintenance & Mods (L322) > Alarm keeps going off - neighbours not happy
Page 3 of 3 <123
ruffy
'Beeper' disconnected before going to work this morning. It sits in a little metal box behind the bonnet switch, just two bolts and a push connector to deal with. I will sort out trying to find what is causing the problem at a later date, but at least for now the neighbours will get a good night's sleep. Thanks for all your replies. 1982 SIII 88” diesel
2007 Discovery 3 V8 S
All gone: 2007 Overfinch TDV8
2007 Supercharged
1991 Vogue SE 3.9 V8
2000 Defender 90 Td5
Post #375319 2nd Mar 2016 1:12pm
Stormin
2003 Range Rover HSE Td6 Epsom Green
Having the same problem with my 2010, alarm keeps going off whilst I'm away. Her indoors says that a message came up saying it was the bonnet. Where is the switch.
I'll try and find it when I'm back
Thanks Three things in a blokes life his dog,his car and a Cornish pasty,nothing else matters.
2010 Range Rover Vogue SE Santorini Black, Arabica Aniline seats
Previous cars
1973 Mini 1000
1971 Hillman Avenger
1975 Chrysler Sunbeam
1981 Ford Cortina
1985 Volvo 340
1989 VW Golf
1989 Volvo 240
1991 Volvo 240
1991 Jaguar Soveriegn
1996 BMW 730
2003 Honda CRV
1999 Jaguar Soveriegn
2003 Range Rover HSE Epson Green with Sand trim.
Post #438813 18th May 2017 3:58pm
GGDR
Follow the left edge with the bonnet open towards the windscreen & you'll see it.
Try electrical lube on the connector & switch.
If that doesn't work, replace the switch.
Mine went off a few times but (touch wood) has been fine since I lubed the connector with "Contralube 770". http://contralube.com/contralube-770/ This is very good marine-grade stuff.
Touch wood again.
. Cheers, Greg
Post #438816 18th May 2017 4:51pm
miggit
I had a Landcruiser that kept on doing this and it turned out to be the door switch...it had worn down and wasn't getting pushed in quite far enough..... a blob of glue a 1p later all fixed! The extra travel that the 1 pence piece gave solved all the problems.... sometimes there really are cheap fixes Wink Yesterday I couldn't spell Engineer... Today I are one!
Post #438855 18th May 2017 11:12pm
p38arover
Australia
miggit wrote:
It can happen you know Whistle in fact that was one of the Landcruisers fav tricks, broken wires in the rubber cable guide, didn't half play havoc with the central locking and the windows Shocked Shocked
Rubbish! Ask on any non-LR 4WD forum in Australia and you'll soon be told that Land Cruisers never have problems. Laughing
RP123 wrote:
On our 'older' TD6 you can turn off the interior sensors (great when you have a pooch in the boot!) by wainting a couple of secs after the first press of key fob lock -then pressing the lock (ket fob) again.The red alarm light on the dash does a long flash when done correctly
After I installed the Engel fridge in my L322, the alarm would, every so often, go off. I finally realised it was the interior motion sensor detecting the air movement when the fridge started up and the fridge fans turned on. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #438857 19th May 2017 12:56am
Page 3 of 3 <123
