Home > In Car Electronics (L322) > Bluetooth ulf update
Brooksy
England 2002 Range Rover Vogue Td6 Baltic Blue
Finally got telephone in white on the screen and my phone paired, however I have to leave the phone in the boot or the connection drops out. I have fitted the Bluetooth antenna, the phone book can be accessed but when I call someone I have no sound through the speakers. Really starting to get annoyed with this now it has been one problem after another.
Post #375999 6th Mar 2016 4:25pm
Brooksy
can anyone help ? The aerial that plugs into the bottom of the ulf module, where should the other end be connected to ? Mine just goes to a similar white connector and is not plugged into anything ! 😱 Wished I had never started trying to for this and just bought a parrot
Post #391789 15th Jun 2016 5:28pm
mjdronfield
One end goes onto the ULF, I used the end with the 90 degree bend in it, and the other end goes to the Bluetooth antenna, that you should have fitted to the 2 bolts on the frame above the sat nav unit..... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #391792 15th Jun 2016 5:46pm
