![]() | Home > Technical (L322) > Stone stuck in brake? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35812 ![]() ![]() |
try reversing...i did this when i got a stone stuck on an off road salisbury plain trip, made a right racket....
rangeseb Member Since: 06 Nov 2015 Location: Baldock North Hertfordshire Posts: 185 ![]() ![]() ![]() |
Stan i jet washed it and did the forward and reverse but nothing.
sorry cant help with a cost, but i would avoid a main dealer and try and find a good independent....... ... - .- -.
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8096 ![]() ![]() ![]() |
I got mine from Dan - less than £100 for a refurbished unit +refundable deposit once I sent mine back.
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3982 ![]() ![]() ![]() |
I think you might possibly have worn down the brake pad so that the metal backing plate of the brake pad is now rubbing on the brake disc. I would get it checked. |
to be honest nicedayforit, i can't see any brake on the pad, it does look like nothing is there. I really hope its the pads are finished or just a stone, cheap fix. |
It could be just the pad worn completely down but I did once have a brake pad where the brake material simply tore away completely from the backing plate for what seemed like no reason. Same result, you need to get the wheels off and check. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8755 ![]() ![]() ![]() |
If it is the pads, and that seems most likely, then you may have a sticking calliper as well, there is a pad warning sensor on the rears and if that is not on then the pads have worn down unevenly which would indicate a sticking calliper..
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
well my indi is busy and cant fit me in tomorrow so i got it booked into the locate Pro Tyre tomorrow morning to have a look. at least this way and can find out the problem and go from there. hopefully a straight forward fix!?
Finally home and had a look at the brakes as the Wife has been only able to update me by phone.
I'm afraid I would be very surprised if you didn't need new discs as well but it depends on how long you drove it with no pad on the plate |
Thanks axle,
FYI if you are planning on keeping the car.... Kwik Fit give a lifetime guarantee..... ie. you only pay for one set, no matter how many you use..... most cars a set of pads will outlast ownership.... but if you tow, carry heavy loads, etc. you can go through brake pads like they are made of butter, and something like this should be considered.... when I was towing with the Landcruiser I could do a set of pads in, in 15K |
