Home > In Car Electronics (L322) > '04 Blank Sat Nav Screen
Knips
United Kingdom 2017 Range Rover Vogue SE SDV8 Santorini Black
Hi everyone,
As the title says the Sat Nav/Radio/Comp screen has gone blank. Power to the unit and buttons 'do' things and the radio works.
I have tried disconnecting everything in the audio cubby hole cleaning connectors and checking for water ingress, I have had some water in there before and a 'shedder' is fitted. Light and whirring from the Sat Nav so that has power.
I have tried powering up with everything disconnected in the back in the hope I would get some sort of default display on the head unit but nothing,
I have disconnected the battery, done an overnight charge and reconnected with a steering wheel reset but no display. I have also checked the 30A main audio fuse in the glovebox.
So before I take the likely next step and have the head unit out and fit one from a breakers (look to be about £170 on ebay) I wondered if anyone could suggest any further tests?
Thanks Knips.
Post #371064 7th Feb 2016 3:12pm
andyboy
Wales 2004 Range Rover Vogue Td6 Java Black
Mine went like that, it was moisture getting into the sat nav unit. When i took the top off the sat nav unit it was all rusty on the circuit board, had to buy another unit of the bay of fleas. Very Happy gone fishin'
Post #371125 7th Feb 2016 7:42pm
mjdronfield
Make sure the blue and white connectors on the TVs module are sound if the above doesn't work. If I remember right it's just the blue one. I got one working by easing it up and down whilst live and watching the screen.....
Worth a try. it's daisy chained with the sat Nav.... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #371127 7th Feb 2016 7:47pm
Knips
Thanks both for your suggestions!
Post #371150 7th Feb 2016 9:17pm
Knips
Ok I am just going to update this thread and close it.
I replaced the display unit and guess what - no display - so back to the back of the car.
I removed both the TV module and the Sat-Nav from their mountings so I could see clearly and carefully check the connector sockets and plugs. I cleaned the socket pins and on close inspection pin 1 of the TV tuner socket was corroded through.
Pin 1 & 10 is the TV module power connection (see the following pinout diagram). Power should also come in through 2 & 9 but on dismantling the blue plug it was clear that pins 2 & 9 were not connected so the break on pin 1 meant no power to the TV.
Easiest fix was to bridge the connector.
This was done by popping the cover off the TV module (the tin box is press fix) and then soldering a wire to the internal pin of the connecter for pin 1 and this was fed out through the ventilation slots. "nicedayforit" http://www.fullfatrr.com/forum/post148622.html posted the wire connections for the plug:
Front of car
O Red / Green O Brown
O Blank O Blank
O White / Grey O Brown / Red
O Blank O Blank
O Black O Black
O Black O Black
O Black O Black
O Blank O Blank
O Yellow / Red O Yellow / Brown
Rear of car
The new wire from the TV module was “T-eed in”and soldered to the power wire.
Normal service resumed.... Very Happy
Post #377271 13th Mar 2016 8:22pm
Well done.. cheap fix as well... presuming you can sell the screen you bought..... Pete
-Click here for Thread-
Post #377285 13th Mar 2016 9:08pm
