![]() | Home > Technical (L322) > Tow bars |
Pilgrimmick Member Since: 11 Mar 2016 Location: West Coast Posts: 64 ![]() ![]() ![]() |
Not asking about the tow bar, but the electrical connectors instead?
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 553 ![]() ![]() ![]() |
Thanks, but what I really want to know is whether the towbar and associated electrickery is compatible. In other words can you take everything off of the 2003 car and fit it directly to a 2006 TdV8? Drives:
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
I believe it's a different system on the later models but you could check on the PF Jones website as it allows you to choose tow bars and wiring kits for different models and years of manufacture. Westfalia is the OEM kit I believe |
Ah, thanks. I'll do that tomorrow when I'm more awake! Thanks again. Drives:
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16399 ![]() ![]() ![]() |
Yes you can ish!
Very helpful guys, much appreciated. Drives:
