![]() | Home > Maintenance & Mods (L322) > 2003 V8 4.4 cam chain replacement interval |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8797 ![]() ![]() ![]() |
They don't have a change interval, that's cambelts....
As Pete says, they never need changing BUT... Its been mentioned on here several times the guides are weak so they do often have problems! |
Weejock Member Since: 31 Dec 2011 Location: UK Posts: 419 ![]() ![]() |
As Haylands said there is no interval however they do have issues with broken plastic timing chain guides. If it rattles it's usually the broken guides that are causing it (or failed tensioner), checked by dropping the sump and looking for plastic bits in the pan. If it's quiet then don't worry.
Boodog Member Since: 23 Mar 2016 Location: Wales Posts: 5 ![]() ![]() |
Thanks everyone |
