Home > Technical (L322) > Mecha Error
David
Spain 2007 Range Rover Vogue SE TDV8 Zermatt Silver
Mecha Error
Keep getting this error on a blue screen when trying to get the DVD working ?
Post #36371 16th Nov 2010 7:23pm
DMRR
A single DVD, or all? I found quite a few wouldn't play in my genuine RSE on the 2006, usually ones with complex play menus..... Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #36373 16th Nov 2010 7:27pm
David
all round, tried all sorts of DVDs !!!!
Also where the musty dvd is in the car there is a single unit above it ? Is the single the sat nav ?
Post #36381 16th Nov 2010 7:36pm
DMRR
Single above the thing that takes the cartridge is the sat nav yes Smile Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #36383 16th Nov 2010 7:38pm
David
Anyone else ? Dan ????
Post #36401 16th Nov 2010 9:09pm
dan_uk_1984
#9
Post #36419 16th Nov 2010 10:13pm
David
dan_uk_1984 wrote:
#9
EY ????
Post #36428 16th Nov 2010 10:28pm
Dolphinboy
Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Thumbs Up
Post #36475 17th Nov 2010 10:00am
David
do you want to infom me ??? whats so funny ?
Post #36557 17th Nov 2010 4:21pm
David
went into Land rover and they had no idea !!!! Any help appreciated.
Post #36611 18th Nov 2010 9:31am
Fox
Googled... Smile
Quote:
ON SCREEN FAILURE MESSAGE FOR MECHANISM ISSUES
NOTE: If there is a mechanism error on the DVD changer, the unit will display 'MECHA
ERROR' on the rear LCD screens and the High Line Display Front (HLDF) screen. The
message will remain until the mechanism error has been resolved.
1. Press the eject button to confirm a fault is present.
2. Observe the message disappear.
NOTE If the fault still exists the message will reappear. An Internal fault in the DVD player is
only one possible cause.
3. If the message reappears, determine the possible Root Cause and a solution as follows:
• Determine if a DVD Changer cartridge is stuck in the DVD Player.
• Eject the cartridge
• Inspect for an incorrect magazine in DVD player (e.g. a CD magazine).
• Investigate for an incorrect disk type causing jamming of mechanism.
• Insert the cartridge into the DVD player.
• If the message returns, insert an alternative disk or magazine to eliminate the originally installed
disk as the cause of the problem.
• If the message remains, cycle the vehicle ignition.
• If required, disconnect and reconnect the vehicle battery.
If that doesn't work. You may have had it. Internal DVD player error possibly. Question
And this is from a LR technical sheet. Rolling Eyes
Post #36619 18th Nov 2010 10:02am
Fox
Also if you want to know about #9 you need to read this thread...
http://www.fullfatrr.com/forum/topic2958.html
Post #36621 18th Nov 2010 10:16am
David
still none the wiser !!!!
Post #36628 18th Nov 2010 10:38am
but a thankyou to FOX for finding out the info might be appropriate.. Wink ... - .- -.
Post #36629 18th Nov 2010 10:40am
David
Fox wrote:
Googled... Smile
Going to try the reset tonight, it is accepting and ejecting the cartrges fine, however when i do insert the cartridge the eject button keeps flashing blue at me. It was working fine before
Post #36630 18th Nov 2010 10:40am
