Home > Technical (L322) > accelerator pedal position senser
cowman
United Kingdom 2005 Range Rover Vogue SE Td6 Adriatic Blue
hi ,have i got a pedal position senser problem ,i cannot hold the revs steady at 1500 rpm as soon as i get to that figure it just revs up and i have to let the pedal off ,and while driving i get a bit of rev counter fluctuation at 35 to 45 steady driving,2005 td6.
Post #379990 29th Mar 2016 8:15pm
Could be the pedal or the engine ECU or the pump etc... Code read should help, also check live values from the pedal.... Pete
Post #379991 29th Mar 2016 8:21pm
Mr Tee
Pedal is a dead easy thing to replace, not too expensive either.
Post #379995 29th Mar 2016 8:48pm
