Home > In Car Electronics (L322) > L322 no audio
Landy01
United Kingdom 2005 Range Rover Vogue Td6 Santorini Black
L322 no audio
Hi, I have a L322 TD6 2005 and the audio has stopped working. The sat nav works ok but there is a flashing Amber light, the only way I can get to the sat nav is to go into override function.
I have checked all fuses in front and rear drivers fuses/ relays.
I have seen some people say there is a fuse in a cable rear passenger side compartment?
I'll upload a picture of the rear passenger compartment and the message on the most test.
Any help at all would be great as I've checked fuses and disconnecting for 30 minutes and disconnecting battery but nothing.
Post #380604 3rd Apr 2016 9:24pm
Landy01
Photos as above
Post #380605 3rd Apr 2016 9:27pm
The thick white cable with the black tape wrapped around it in your pic is called the MOST ring... One of the components in the MOST ring i would suggest has failed... Usually the bluetooth module! (top of the stack with NOKIA printed on the top)
You will need to unplug the ring one at a time and use either a bypass tool, or make your own (see wiki for a how too) until you find which component has failed Thumbs Up
Post #380627 3rd Apr 2016 11:46pm
Landy01
Cam tech Craig - you were spot on. I now have audio but the CD player doesn't work, do I need to replace the Nokia box?
Post #381442 9th Apr 2016 3:42pm
