Home > Technical (L322) > 2 Questions in one post
David
Spain 2007 Range Rover Vogue SE TDV8 Zermatt Silver
1, How do i do a battery reset ? I was under the impression that i open bonnet and close doors for 10 mins, remove terminals from battery and wait for 10 mins. Then hold the two connectors together for a few seconds then reconnect the battery ? Is this correct ? Also what will it do ?
2, RAVE. I keep trying to download it, but once it is downloaded what the hell do i do with it !!!!
Post #36612 18th Nov 2010 9:39am
SteveMFr
Site Sponsor
1. Basically, that's it. Don't know why you need to close the doors, tho. You DO have to wait a couple of mins after opening the bonnet and removing the key before removing the batt terminals to ensure that the satnav has had time to shutdown properly.
What it does is remove all residual power from all the little computers, ecus, and other electronic devices in your RR so they all have to reboot - same as your PC. This hopefully removes any glitches when they're all up and running again - same as your PC.
2. Depends where you downloaded it and what you have, but generally it's an .iso image that either needs to be burned to CD to run or mounted on your HDD as a virtual cd which you can then run all the time. Google will help you further...
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #36614 18th Nov 2010 9:49am
dan_uk_1984
Makes a change from 1 question and two posts I supose!
Post #36618 18th Nov 2010 9:58am
SteveMFr
Site Sponsor
This seems to have been 2 questions in 2 posts Laughing
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #36623 18th Nov 2010 10:22am
David
Dan if people didn't have questions there would be know where for you to spend all day showing how knowledgeable you are !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Post #36631 18th Nov 2010 10:41am
dan_uk_1984
I think you missed my point. You said 2 Questions in one post - but you posted it twice, so now there are 2 posts.
Post #36636 18th Nov 2010 11:00am
so its 2 posts and 4 questions then... Very Happy ... - .- -.
Post #36638 18th Nov 2010 11:02am
Fox
Only 4 questions?
The first post has 4 question marks in the first part. Wink
Is this correct ?
Note to self... get off this forum and do some work. Laughing
Post #36640 18th Nov 2010 11:12am
question?, is a question a question or not a question if its got question marks.. ... - .- -.
Post #36642 18th Nov 2010 11:16am
dan_uk_1984
Question
Post #36643 18th Nov 2010 11:28am
Martin
Site Admin
Fun over - I've merged the threads Laughing
Post #36644 18th Nov 2010 11:58am
Spoilsport Big Cry
Post #36646 18th Nov 2010 12:31pm
In the English language, the question mark (?), also known as an interrogation point, interrogation mark, question point, query, or eroteme, is a punctuation mark that replaces the full stop at the end of an interrogative sentence. The question mark is not used for indirect questions. The question mark character is also often used in place of missing or unknown data. Thumbs Up
Post #36647 18th Nov 2010 12:32pm
David
HAHAHAHAHAH
Post #36649 18th Nov 2010 12:34pm
VMPP
Portugal 2007 Range Rover Vogue TDV8 Buckingham Blue
The RAVE will serve you for almost nothing.
It's just the ''workshop manual'' for pre 2006 cars.
The newer cars use different systems. Engines is worthless, electrical the same...
Nevertheless you can still use it to check where some of the parts are. the suspension compressor, mountings, etc...
Post #36799 19th Nov 2010 12:45am
