Home > For Sale & Wanted > [Sold] Genuine Land Rover Roof Rack 2002-2012
miggit
I have a Genuine L/R roof rack up for grabs, it is in reasonably good shape, but does have a very slight ding on the corner above the drives 'A' post, it is the later style and has the step in it to get over the Shark's Fin Aerial. I'm looking for £300, collection from Milton Keynes, assistance will be given to transfer to another ffrr
Ding is so slight that it really doesn't show... it took me 6 months to notice it Laughing
The Rest
 Yesterday I couldn't spell Engineer... Today I are one!
Post #381137 7th Apr 2016 11:10am
p38arover
Australia
Wrong bloody country! Evil or Very Mad
Big Cry Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #381141 7th Apr 2016 11:40am
miggit
Whistle If you want to drive over it still could be yours Laughing
They are rather like Rocking Horse pooh... I don't expect it to stay long Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #381142 7th Apr 2016 11:47am
sako243
Craig was interested in mine but I ended up selling it to someone more local. Perhaps he's still interested? Ed
Post #381171 7th Apr 2016 5:25pm
miggit
We shall see Whistle It's still unclaimed as yet Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #381184 7th Apr 2016 6:48pm
jambo27
Forgive my stupidity but do i need anything else to fit this to my car ? I have the little plastic trim bits that push out. I am assuming the feet just fasten in there or do I need some other fixings ? 2008 TDV8
Post #381186 7th Apr 2016 7:24pm
sako243
I assume that Paul will include the fixings.
Basically of you lift up the plastic trim carefully then there are some grub screws to remove (6mm if I remember correctly). Then the rack has a number of brackets that sit in the channel. You then locate the rack on all of them and place the screws through the whole stack and bolt into the roof.
Theoretically you should check tightness after a few hundred miles as it settles / shifts.
So in summary you need an Allen Key and possibly small screwdriver for lifting the flaps. Ed
Post #381189 7th Apr 2016 7:56pm
can't think of a reason that this wouldn't fit a 2010->?
Quite fancy it, don't know what i would use it for though, but tempted non the less.... Whistle There is nothing that can't be fixed with a hammer😜😜
Post #381190 7th Apr 2016 8:08pm
MartSim73
Hmmm... Would it fit a MY11 FFRR?
Post #381192 7th Apr 2016 8:38pm
can't see why not, the mounting points are in the same place and it has the raised bit for the antenna at the rear. Just wondering if the sharks fin on the latter models is a little larger though? There is nothing that can't be fixed with a hammer😜😜
Post #381196 7th Apr 2016 9:13pm
supershuttle
Shark Fin is smaller on my 2010 than on my 2007 Geoff
Post #381197 7th Apr 2016 9:25pm
supershuttle
Do the flaps break in any way - I guess what I'm asking is when the roof rack is removed do the original plastic bits got back OK? Geoff
Post #381199 7th Apr 2016 9:31pm
if you look at the pics you can still see the flaps in position, so i was assuming that they could be left on. There is nothing that can't be fixed with a hammer😜😜
Post #381200 7th Apr 2016 9:33pm
sako243
They just fold up. The mounts are designed to sit over the top of the flaps.
You do need to be careful though as they are easy to snap. Ed
Post #381201 7th Apr 2016 9:36pm
miggit
As Ed has said the flaps are just hinged out of the way, not snapped off like you do when fitting the roof rails.... this can be removed without a trace. And yes a full fitting kit will come with it along with assistance to fit it.... otherwise how else would you get it home? Thumbs Up
As far as fitting a later car goes, I'm happy to give it a try, they are listed as 2002-2009 but that might just be because they were described in 2009, and they couldn't see in to the future Wink
Is there a listing for 2010-2012 that is a different part number? Yesterday I couldn't spell Engineer... Today I are one!
Post #381205 7th Apr 2016 10:04pm
