Home > Technical (L322) > headlight bulb sometimes fails ?
cookie42
2005 Range Rover Vogue Td6 Java Black
every now then the headlight on my rr stops working . i get the check bulb warning on the dash but the strange thing is if i turn the lights of then back on it works again ?
what would be failing here ? the bulb or something else ?
many thanks
Post #36767 18th Nov 2010 9:06pm
if you got xenons it could be the igniter/ballast or the hid bulb..... by switching on again you 'start' the xenon therefore making it work again.. ... - .- -.
Post #36768 18th Nov 2010 9:10pm
