![]() | Home > In Car Electronics (L322) > How to swap TV tuner |
zarnd Member Since: 22 May 2014 Location: Kent Posts: 459 ![]() ![]() ![]() |
Got my hybrid tuner today and tried to fit it tonight.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8755 ![]() ![]() ![]() |
As Craig says, take it easy and take pics before you take it apart, it's all on 8mm and 10mm nuts...
Great, what I thought it would end up being. I'm guessing the tv tuner is bolted from the rear.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16398 ![]() ![]() ![]() |
Yes, start at the top & work your way down sir |
No, I can borrow one and will try and label the wires to each control unit on the correct position it should be in.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35808 ![]() ![]() |
can you not just clamp the new tuner onto the existing stuff and move the cables... ... - .- -.
There isn't any space to put it somewhere else.
ah, had you not had the rse stufff in there then you could probably do what i suggested.. |
Took about an hour and a half from start to finish including my three year old helping me do it.
RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597 ![]() ![]() ![]() |
Upgraded mine from analogue to hybrid digital back in 2010. Wrote what I had to do here...
When I started I was labelling the connectors as at first glance at dusk a few nights before they all looked similar. Like you say they are all colour coded and sized so impossibe to not get right when putting back. My tuner was exactly the same size as the one that wa removed so used all four bolts. Didn't have to disconnect any HK stuff as I was able to lift out the tuner and HK unit on the metal bracket in one go and turn it over to remove and swap.
Hi Alex, yep , same as me , first time I did it I thought it would be a nightmare but wasn't due to the uniqueness of the connectors and I did do it a second time and was literally 20-30mins from memory |
