![]() | Home > Technical (L322) > Changed Puncture and now fault |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8755 ![]() ![]() ![]() |
Constantly filling up the system, usually indicates a small leak in a bag, you could have tipped it over the edge with jacking it up, a part of the bag that never gets folded, will be folded, and has probably developed a leak... out with the soapy water in a spray bottle, then get suspension all the way up to off road and squirt away.... |
welderman Member Since: 03 Oct 2015 Location: Lancashire Posts: 14 ![]() ![]() ![]() |
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 613 ![]() ![]() ![]() |
Conceptually the bags aren't too difficult to replace. However...
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
umm When you say "Blowout" was that it went flat and still looks like a tyre, or was it totally disintegrated and looks like a few bits of rubber stuck on a rim....... |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16398 ![]() ![]() ![]() |
The OP has a 4.4TDV8 so the front legs are twice the price of yours from island 4x4 ![]() ![]() ![]() |
Electronic adaptive dampers.... Pete
I stand corrected.
And thats the much cheaper after market Island 4x4 route |
The rear drivers tyre went pop has a hole big enough to put your finger in, lucky for me I was just entering a 50mph zone on the motorway. The rest of the tyre was fine, the side wall was |
No particular reason apart from it's what went on mine and I was guessing that if a tyre went it was more likely to be a front as that would hit something first. Ed |
Right so the bad news is you are still feeling a little deflated |
Just popped down to Landranger in Atherton, only 25 min from me, Martin deleted the fault code and hopefully that sorted it. Fingers crossed.
