Home > In Car Electronics (L322) > Venture Cam Holster / Dock repairing latch mechanism
StewD
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
I've seen plenty of RR with the venture cam hanging out in the dock/holster.. Mine included 🙄
It appears to be a common issue, does anyone. Have experience of repairing the latching mechanism ?
I'm going to try and remove it to work out what's happening to mine
Post #383466 24th Apr 2016 10:21am
StewD
A quickly slung together how to guide for repairing the Venture Cam Dock latch mechanism.
Difficulty 1/5
First is to get at the enclosure to remove it from the dash
Pop the side cover off
Remove a few screws on the bottom section of the exposed dash
Remove kick panel scuff guard and footwell trim
Remove screw from here on underside of dash
Remove grommet from inside of dock
Remove another screw
Pull enclosure towards the rear of the car and out, but don't get carried away there are 2 cables to remove
Try not to shake the enclosure too much, the broken tab will hopefully be rattling about, it's very small.
The enclosure handily has no holes for it to fall out of 👍
Find yourself a seat....
Remove the dock from the dash unit, just a few screws required.
Here is where the tab should live....
Here's the tab
A spot of superglue, a steady hand and a pair of long nose pliers and hopefully you'll end up with this...
In true Haynes fashion reassembly is the reverse of disassembly...
Post #383486 24th Apr 2016 12:50pm
dan_uk_1984
Thanks for this, great info.
Not sure it will help me as my cam locks until I go over a bump and then it falls down. But I'll follow your instructions and see what's going on.
Sheep
Post #402164 26th Aug 2016 10:27pm
StewD
You're welcome.... it's a team game Cool Current: Supercharged 06 FFRR in Java Black
Previous: BMW 740D M Sport
Previous Previous: BMW 730D Sport
Post #402168 26th Aug 2016 11:18pm
appj62
England 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Using a cut off beer mat is a lot less hassle! Previous cars:
S-Max 2007-2013 (only diesel I've had, good car but expensive when diesely bits go wrong, so what's the point?)
Galaxy 2001-2007
Mondeo Estate 1997-2001
Sierra Estate 1993-1997
Uno Turbo 1987 -1993
Fiesta 1984 - 1987
Fiat 127 1982 - 1984
Post #402187 27th Aug 2016 8:47am
Nice write up... Thumbs Up Thumbs Up
appj62.... how do you take video with a cut off beer mat...??? Pete
Post #402190 27th Aug 2016 9:19am
TimperleyRR
United Kingdom 2006 Range Rover Vogue SE Td6 Buckingham Blue
Dear Stew D
Your write up was invaluable in repairing my venture cam dock. Unfortunately the broken part of my clip was nowhere to be seen so I had to source a new unit. Found one on flea bay:
http://www.ebay.co.uk/itm/222169957989?_tr...EBIDX%3AIT
The price at £15 seemed too good to be true - given that LR quoted £220+. Unfortunately it was too good to be true and it would not make a wireless connection to my unit. The circuit board appeared identical but had a different model number on it so could have been for a newer model.
However it worked out fine for me as I just swapped my old circuit board in to the brand new housing complete with intact clip and hey presto - all good. At £15 cannot complain.
Post #402206 27th Aug 2016 11:51am
StewD
Haylands.... they all seem to have a wedged beer mat piece holding them in.... mine did when I got it... 🙄 Current: Supercharged 06 FFRR in Java Black
Post #402493 29th Aug 2016 11:20pm
appj62
Must admit I don't use. When I need to admire it, I just pull the dock down and scrabble about in the foot-well to retrieve the beer mat! Smile Previous cars:
Galaxy 2001-2007
Fiesta 1984 - 1987
Post #402556 30th Aug 2016 12:09pm
