Home > Maintenance & Mods (L322) > Check your tailgate straps
To all those who don't know yet or are new , check the straps after winter . I did mine 4 years ago and it's dry here 😦
 2008 MY Supercharged
Post #385160 4th May 2016 8:56am
Update , I did the other side when I fitted the soft close😡 but anyway check them 👍 2008 MY Supercharged
Post #385162 4th May 2016 9:04am
Road Stone
Hi Axle,
Do you live near the sea, or been driving on the beach?
After only four years something caused it.
Cheers, Jerry THIS WRECKAGE
Post #385182 4th May 2016 12:24pm
very common problem.. the water from the rear screen runs down to the strap bolts and rusts them..
one of mine broke whilst my wife and i were standing on the tailgate , luckily my wife just jumped down and i was starting to ... ... - .- -.
Post #385184 4th May 2016 12:49pm
Road Stone
So from washing the car too I guess.
Just checked mine, look new.
As you say something to keep an eye on.
Post #385204 4th May 2016 2:38pm
EmiratesA380
United Kingdom 2019 Range Rover SVAutobiography 5.0 SC V8 Aintree Green
Hi Axle
I have a few days off and can you believe I did this on both cars today.
They weren't as bad as your picture - only a slight rust on the face - however I took off both straps and took apart - placed them in a vice and wire brushed the ends.
Then I ve sprayed Hammerite Black over he metal - left in the sun all afternoon and they are rock hard coated in Hammerite Black - that should stop any rust getting their
Easy job to do and I think it would be well worth the effort.
Note: when you do up the nuts ( both top and bottom ) leave then slightly slack as movement has to take place in order for the strap to fold down.
anyway - good post Alex - well worth mentioning to all FFRR owners Thumbs Up
Post #385255 4th May 2016 9:08pm
p38arover
Australia
Same applies to the P38A. Sad Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #385292 5th May 2016 12:09am
rar110
I just replaced mine after one broke.
A smear of grease under the rubber cap once a year would help a lot I think. ______________________________
Post #385342 5th May 2016 12:20pm
Dogfishdave
United Kingdom 2010 Range Rover Vogue SE 4.4 V8 Santorini Black
Did both of mine last week.
Just in time I think, they were bad
Post #385346 5th May 2016 12:35pm
Was never an issue with the Classics....
 Discovery 4 HSE
Post #385350 5th May 2016 12:55pm
pic of my strap on me old td6,
http://www.fullfatrr.com/forum/topic12664....ate+straps ... - .- -.
Post #385352 5th May 2016 12:57pm
EmiratesA380
Love your Rangie as your supposed too !
Here's what Ive done - easy to do - just ensure you photograph all the pieces before you take apart to help when you rebuild - NOTE: do not tighten up nuts too tight - they have to have a bit of slack in in order to move when tail gate is closed. ( check when you have finished )
Hope this helps anyone.
Post #385620 6th May 2016 8:36pm
Brian
Good job I read this thread Shocked I just looked at mine and they are in really bad condition so I better order a couple up and get them fitted Thumbs Up
Post #385642 6th May 2016 10:43pm
