Home > Maintenance & Mods (L322) > Battery life
cheezels
Australia 2007 Range Rover Vogue TDV8 Java Black
Battery life
Wifey took boys to NFL.
Whilst one was training, my other son watched a DVD using the RSE.
I get a call to say the Rangie won't start, battery is dead.
So, my question is, would watching a DVD for a couple of hours really drain the battery that much, or is the battery on its last legs.
Cheers
Post #387310 16th May 2016 11:46am
you should never do that..the FF's battery isnt up to the job and you must have the engine running if you watch a dvd or tv.. ... - .- -.
Post #387311 16th May 2016 11:53am
cheezels
Copy that.
Thanks Stan
Post #387312 16th May 2016 12:15pm
wealy
United Kingdom 2014 Range Rover Vogue SDV8 Luxor
Your system should shut down automatically????
Post #387324 16th May 2016 1:52pm
cheezels
Yeah, I thought the same thing.
My mates Toyota does. So on the basis that Toyota copy Land Rover, I thought the same would be for mine
But apparently not
Maybe an IID tool could find this setting?
Post #387328 16th May 2016 1:56pm
mzplcg
You can get some more life out of it by adding a 2nd battery in the boot. I did this on an 07 VSE and it would still start after a couple of hours. You can get a Gel battery for the front of 105ah and a similar one for the back of 60ah. Both will deep cycle and still give a start at 70% discharge.
Front
https://www.tayna.co.uk/H15-Varta-Start-St...P8824.html
Back
https://www.tayna.co.uk/D52-Varta-Start-St...P8823.html
Those are a UK supplier but you should be able to find similar in Oz.
Post #387332 16th May 2016 2:02pm
RSE does NOT shut down like the front screen when the battery gets low Rolling Eyes
As Stan says, the car should be left running whilst RSE is being used! Handy if you leave the kids in the car without a driver hum... Whistle
Post #387338 16th May 2016 3:15pm
Flashman
The RR is barely able to power the clock without draining the battery over a few days, I am tempted to add a second battery in the boot. Tom
Current Drive
Previous Drives
Post #387351 16th May 2016 4:36pm
Dolphinboy
Mine has the second battery in the boot (courtesy of dan_1984_uk) and have never had a prob. Original LR battery too! Now over 7 yrs old!
Here's how he did it.
http://www.fullfatrr.com/forum/topic5721.html?highlight=battery
Post #387396 16th May 2016 6:22pm
MrKev
Re: Battery life
Unnecessary quote removed
Not an isolated experience, I and a friend have both had similar experiences. Makes you worry though - implies 20-40A average current drain just watching the telly... approx 240-480 Watts. My mac mini and 7" TFT screen drew around 10 Watts playing a DVD.
Post #387400 16th May 2016 7:13pm
mjdronfield
I've just spent £200 on a decent cool box that heats and shuts down if battery gets low - I thought might be handy if I buy milk at dinner at work as I can't be bothered to call at the shop on the way home....
Beginning to think it'll run for 5 mins and then shut off due to battery..... Could be money not well spent.....
Embarassed 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #387401 16th May 2016 7:13pm
mzplcg
As Dolphonboy pointed out, the 2nd battery gives another 60 or so amp hours. My Engel was left on pretty much all the time and never caused a problem. Mind you, if yours has a Peltier unit it will draw a lot more current than a compressor fridge does as the compressor turns off once it's down to temperature.
Post #387405 16th May 2016 7:28pm
