![]() | Home > Technical (L322) > L322 key battery/alarm problems |
Hi Guys
You may have just confused it by not shutting the door correctly - if the problem doesn't come back chalk it up to one of life's mysteries. If it does it again - disconnect the battery for 5 mins and re-connect to re-boot everything.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35859 ![]() ![]() |
just a thought, wouldn't the key being in the ignition turn the immobiliser off ... ... - .- -. Y. O. L. O. . |
I was thinking the same about the immobiliser. To be fair I've had the car for 8 months and never heard the alarm untill a few days ago. 1st was when I locked the car with the dog in, the second was the other night when it went off randomly I put it down to a spider who's decided the rangy is a good place to live. Could they be linked? The battery in the fob is a CR2016 the replacements were DL2016's. Both the replacements didn't work but when tested with a meter gave 3.2v. Does this sound like a problem? |
the dl2016 is a replacement for the cr2016..what voltage does the 'cr' give, is it the same as the 'dl'......what dan says re disconnecting the RR battery , it does work wonders...it could be wise to test it as well as these cold days show up many faults on the RR if the batterys on the way out... ... - .- -.
I know they do oftern have mood swings! What's the best way to disconnect the battery without causing more problems? How do I test the battery? Check the voltage across the terminals with a meter? |
rob, just undo the nut/cable that is enclosed in the little plastic box , ...you need to do a drop voltage test which will probably have to be done at a tyre shop or by an auto electrician.. ... - .- -.
