Home > Technical (L322) > Turbo actuator
STU TDV8
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
Turbo actuator
On a TDV8 when you turn the ignition on and off does the turbo actuator do a full sweep or something else ?.
Post #387566 17th May 2016 7:07pm
kbald
Not sure about on switch off but there have been a few posts on here about them doing a full sweep at start up but they can get gummed up and this can cause an engine system fault if they are restricted. You can apparently free them off and get 3 in 1 sprayed on there to solve the issue.
Post #387567 17th May 2016 7:11pm
STU TDV8
Had the turbos rebuilt they were working fine when I removed them now I've refitted them it's low on power low down and engine fault light comes on . Passengers side moves about 12mm and drivers side moves about 2mm when you turn the ignition on but they don't do a full sweep ??
Post #387589 17th May 2016 8:47pm
kbald
Well that's certainly not right! I'm no expert but from what l have read at start up the arms go through the full motion maybe more than once from memory so they should both move at least the same amount. Have you had the codes read? That should give you a good idea of what's wrong if the engine management light comes on!
Post #387593 17th May 2016 8:59pm
Oh dear... No thats NOT right sir... They should go through the full range of movement Thumbs Up
Post #387624 18th May 2016 1:17am
Olly-Ibiza
Who rebuilt the turbos, I know they have to be calibrated once rebuilt and there are very few places with the kit to do it
Post #390734 8th Jun 2016 12:17pm
STU TDV8
Owens development's rebuilt them ...
Post #390736 8th Jun 2016 12:23pm
Olly-Ibiza
Do they have the electronic calibration kit to do it? Iv head loads of people have turbos rebuilt or new cores fitted then just get endless actuator fault issues
Post #390737 8th Jun 2016 12:24pm
STU TDV8
No they said they couldnt test it Sad
Post #390740 8th Jun 2016 12:29pm
Olly-Ibiza
The guy that rebuilt my turbo had to send it somewhere to get it done, I can try and find out where he sent it
Post #390741 8th Jun 2016 12:36pm
Mikey
And for this very reason, I only supply brand new OEM turbos Thumbs Up
Post #390747 8th Jun 2016 12:55pm
STU TDV8
Dont suppose you have an old actuator laying around for the driver's side from an old unit do you mikey ?..
Post #390905 9th Jun 2016 12:20pm
Olly-Ibiza
Soon as you undo the bolts that hold the actuator on you will lose the calibration so another actuator won't be much help
Post #390914 9th Jun 2016 2:03pm
STU TDV8
Dont work now so can't be in a worse situation ?..
Post #390919 9th Jun 2016 3:57pm
