Home > Technical (L322) > Lubricant
Sfrain145
United Kingdom 2003 Range Rover HSE Td6 Oslo Blue
Lubricant
Hi
Just doing a job on the 2003 TD6
What type of oil do I get for the front and rear diff
And the transfer box
Where is the best place to get it from cheers
Post #387661 18th May 2016 12:08pm
mr_spock
Stolen from the wiki and from RRPhil's posts about this on another forum:
Transfer box: Castrol BOT 26 FMB 1
The front & rear differentials require a 75W/90 API GL5 oil although, bizarrely, Land Rover actually specify a different fluid for the front & the rear! The front diff. uses Castrol SAF-XO (p/n TYK500010) and the rear diff. Castrol SAF Carbon MOD Plus 75W/90 (p/n TYK500070).
Capacities are :
Transfer box = 1.0 litres (dry), 0.95 litres (refill)
Front differential = 0.8 litres (dry), 0.75 litres (refill)
Rear differential = 1.2 litres (dry), 1.0 litres (refill)
Post #387662 18th May 2016 12:12pm
Sfrain145
That's great thanks. I take it that's a dealer only set of part codes
Post #387666 18th May 2016 12:22pm
mr_spock
Yes, Land Rover parts. My local specialist keeps the right stuff on the shelf, so maybe call around.
Post #387670 18th May 2016 12:36pm
Sfrain145
Thanks again don't know who my specialist would be as I live in Warrington
Post #387673 18th May 2016 12:40pm
Why not buy them from your local main agent? They are not that expensive at around £25 per diff/transfer box... At least you can be assured of the right stuff going in Thumbs Up
Post #387674 18th May 2016 12:45pm
nicksaab
2016 Range Rover Vogue SE SDV8 Corris Grey
Or google the part numbers to find a mail order specialist with them in stock. Island 4x4 list them on their site and I'm sure Dan @ Duckworths will be able to sort it for you too. Current Fleet:-
2018 Discovery 5 3.0 HSE
2021 Ford Ranger Wildtrack
2019 Ford Mustang Bullitt 5.0 V8
1993 Defender 90 200TDI Pickup
Gone - not forgotten
2016 L405 4.4 SDV8 Vogue SE
2012 L322 4.4 Westminster
2004 L322 4.4 V8 Autobiography LE
2000 P38 RR 4.0 HSE (ex Clarkson test car)
Post #387676 18th May 2016 12:52pm
