Home > Technical (L322) > Loose mirrors
Loose mirrors
Hi Guys
Had a quick search but couldnt find what i was after. The easiest way to describe the problem is that both driver and passenger wing mirrors have quite a bit of play in them. The fold in and out dead as they should but they appear loose. Under hard acceleration (as hard as it can be in a FFRR) the mirrors fold in a bit and under heavy breaking they go out again. This isn't a big problem just a niggle. Is there a way of tightening them up or do i just have to live with it?
Thanks
Rob
Post #37901 22nd Nov 2010 4:52pm
i would remove the mirror and see if you tighten the nuts on the mirror assembly.. ... - .- -.
Post #37905 22nd Nov 2010 5:00pm
Are the mirrors easy to remove without using a hammer? Undernieth the mirrors there appears to be some sort of cover any ideas what it covering/for?
Post #37907 22nd Nov 2010 5:12pm
there are instructions on RAVE..
edit...just in case you havnt got it..
Post #37911 22nd Nov 2010 5:17pm
