![]() | Home > Maintenance & Mods (L322) > Bluetooth Car Battery Monitor |
| Pvw10 Member Since: 04 Nov 2015 Location: Ledbury Posts: 315
Crikey if your really paranoid about your battery this has to be for you;
| boatsandy1966 Member Since: 05 Dec 2015 Location: nr pagelsham essex Posts: 162
I have the Accutire MS-51GB ones on a few boats cars and bikes good kit for pennys 1937 model y hot rod 1000bhp rover75 v8 vincert blackshadow plus several boats and other toyz ! ford f150 raptor Mercedes e class convertible jaguar f pace |
| Road Stone Member Since: 08 Mar 2014 Location: Uganda Posts: 227
Brilliant! THIS WRECKAGE |
| wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020
Have you got this fitted? Does it work well? |
| axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964
I'd be worried about it draining the battery |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35874
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822
Can't see the point myself, it lets you know within 6 meters of the car whether the battery is flat or not, walk a few paces and try to start it and you will get your answer...
Knowing our luck Pete it would fail to send a text as the battery was to low |
| Siftah Member Since: 11 Jun 2018 Location: Barcelona Posts: 351
Here's a version which *can* send you a message when the battery drops below a certain voltage, looks very handy - I've just ordered one |
| AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464
Dont expect too much with the range, 100 metres at best, sturround it with meatl and you may get 10 metres or thereabouts. BMW i3 Electric Car
Yeah, definitely not expecting much range but the car is parked less than 10 metres from where I sleep |
Range isn't much of an issue with this device - it stores the data internally for 24 hours or more, so when you return within range it syncs it down to the app. Works great! |
