Ok here's the update. I managed to drop around 3.5 Ltrs of transmission fluid from the sump plug. Once I'd dropped the gearbox pan down I managed a total of just 5Ltrs plus minimum spillage.
One mistake I made was to remove the sleeve without actually unscrewing the connection plug on the outside of the box, a litthe grunting and head scratching , solution, really install and unscrew then remove the sleeve.sorted.
Rebuild involved locating the lug on the inside of the sleeve and a small amount of leverage to get the sleeve homed in.
Rebuilt and new oil time, the best solution I could find was a hand oil extractor pump, works ace just required a assistant to make the job easy.
A total of 5.5Ltrs of zf fluid went in following the original instructions at the start of this thread curtasy of rrphil (Phil) thanks.
Also, on the plus side the date on the old pan indicates a new pan was installed between 2014 and now as it had 2014 stamped on it.
