Home > Technical (L322) > Wanted- better V8 M62 radiator
p38arover
Australia
Does anyone make a better radiator for the M62 V8 RR than the OEM unit? Mine has started to leak again. It was last replaced in mid-2014.
Surely someone said the OEM unit is rubbish and we can do a better one.
How many of you have had multiple replacements? Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #390718 8th Jun 2016 11:24am
Dolphinboy
I replaced mine with a Hella one. I think that is the OEm one? no probs so far. Thumbs Up
Post #390724 8th Jun 2016 11:38am
p38arover
Australia
Yes, I've seen mention of the Hella unit. I checked with my supplier today and they can get the Hella. Is it the same Hella as in lighting?
I'm thinking of a custom unit. I've sent off a quote request to http://www.aussiedesertcooler.com.au/index.htm Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #390726 8th Jun 2016 11:42am
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
I put a Hella one on mine as well, nearly 5 years later and it's still fine. I thought Hella was OEM too.
Post #390789 8th Jun 2016 4:22pm
p38arover
Australia
What pressure coolant reservoir caps are you using? Mine had a 200kPa cap but now runs a 140. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #390866 9th Jun 2016 12:39am
The very first cars ran a 140 cap, they then went to a 200....
You need one of these, reduces the temperature significantly and also the pressure, rad and everything else under the bonnet lives longer as a result...
http://www.ebay.co.uk/itm/80-C-Thermostat-...xyUrZSwcNg Pete
Post #390867 9th Jun 2016 12:47am
p38arover
Australia
I fitted one of those a few weeks back, Pete.
The car runs about 93 deg C (according to ScanGauge) with our reasonably cool 22-27 deg C days. I wonder what the temps will be come summer when we get 40+
I just had a look at MicroCat and found the cap specified is:
Up to VIN (V)1A001049, it is PCD100200L (which is probably the 200kPa cap)
From VIN (V)1A001050, it is PCD100070 which is the 140kPa cap.
My car's VIN is 34A145nnn so I don't know why it had a 200kPa cap. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #390875 9th Jun 2016 5:57am
p38arover
Australia
Re the above, what I don't understand is the VIN. The 1A indicates a 2001 build/model but the L322 didn't start until 2002.
Mine is 4A - a 2004 MY
Can someone with an early model advice the relevant number on their VIN, e.g. 2A for 2002, 3A for 2003? Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #391051 10th Jun 2016 1:37pm
Mine was Sept 2002 and it's number is 3A******
According to Dan it required a 140 cap which it has had for two years now, along with the lower stat and no issues at all with the cooling system.... Pete
Post #391056 10th Jun 2016 2:00pm
p38arover
Australia
Yep, Sept 2002 is a 2003 MY. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #391161 11th Jun 2016 12:07am
