![]() | Home > Maintenance & Mods (L322) > 07 air suspension highway mode, can the speed be edited??? |
andygts Member Since: 16 May 2015 Location: Yorkshire Posts: 366 ![]() ![]() |
After previously owning a 2002 td6 a few years ago that lowered at around 70mph on the motorway I prefered the firmer ride on the motorway, for some reason LR have increased the speed to 100mph. Can the speed be changed at all?
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35833 ![]() ![]() |
that function cannot be edited ...you can lower the suspension with an iidtool but if you lower the standard mode then the extended and access wil come down the same amount.. ... - .- -.
Thanks I know the default standard heights can be altered, it's the 'highway' speed I'd like edit. Guess I'll have to live with it or have a play when I get an IIDtool and find a happy medium |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1583 ![]() ![]() |
Gawd! At how many places can one legally drive at 100mph? In Oz, they'd lock you up, take your licence away, and hit you with an enormous fine. Ron B. VK2OTC
Thats the reason for wanting to alter, we can't legally do 100mph, limit is 70 and on the stretch of motorway I use for my commute the limit is enforced with speed cameras |
Things are changing but Europe is nowhere near as drakonian about Highway speeding as Australia .Although 100 is now seen as a no no everywhere . 2008 MY Supercharged
berkshirelad Member Since: 06 Apr 2016 Location: Newbury Posts: 265 ![]() ![]() ![]() |
There are still German Autobahnen without speed limits.
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 ![]() ![]() |
The French are tightening up on this too now though. On the toll roads they wait near the 2nd booths where you pay and once your ticket times are checked they can work out the speed and pull you as you leave the 2nd booth. Best thing is nail it from booth one, stop for lunch in an Aire and then mooch through booth 2 as you pay...result |
Duracell777 Member Since: 07 Sep 2015 Location: Warwickshire Posts: 128 ![]() ![]() ![]() |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2748 ![]() ![]() |
If you can't find a good compromise then I produce the LLAMS plug-in kits that can lower (20mm or 35mm) and raise (30mm and 55mm) at the turn of a switch. |
Pvw10 Member Since: 04 Nov 2015 Location: Ledbury Posts: 315 ![]() ![]() ![]() |
Please advise more Graeme ? Many thanks
PM sent. |
