Home > Maintenance & Mods (L322) > 2012 Rear light retrofit
Danwilderspin
i know this has been covered (which is fine) but i have a 2002 and have 2012 rear lights. I know before doing anything i will get the hyper flashing as the check control is checking the bulbs.
I know you can get harnesses etc but would prefer to fix with coding.
Can i use navcoder to code out the check control on the rear lights and then will they be good to go?
Thanks
Dan
Post #391925 16th Jun 2016 7:13pm
You can't code out the cold or hot monitoring on the side lights or indicators no matter what tool you have... Pete
-Click here for Thread-
Post #391931 16th Jun 2016 7:25pm
Danwilderspin
Hi Pete thanks for all the advise so far it's great - I'm definately not saying I disbelieve you but I saw this screen when connected to a rr will this not commit the changes then?
Post #391969 17th Jun 2016 7:33am
ebajema
The various computers and software packages allow for changing settings but if the ECU in your particular car does not have the software to use the additional setting it won't work. I don't know what your car is running but I ran into similar issues with my NAS 4.2 where I changed the CCF but no change could be done to either software or wiring issues.
The computers/software packages are designed to work on all models, hence the option for changing hot/cold monitoring being there but not working on certain models as suggested. Sorry Sad MY 2010 5.0 SC Galway green and sand interior!!
Post #391979 17th Jun 2016 8:36am
Dan, was that computer connected to your car? Or a later RR sir? The LCM on the 02-05 RR will NOT support those changes, however... The LCM on a 05-09 RR will...
You can always buy a LCM for an 05-09 and retrofit it to yours & try it then... I think it will probably work just fine Thumbs Up
Post #391994 17th Jun 2016 10:32am
Danwilderspin
That was mine you can see it says module August 2002 I didn't try to write the changes - I may be wrong but I thought the Lcm was based on the e39 module for which I know this works
Post #392097 17th Jun 2016 11:27pm
Well give it a try, if it works I'll be round to see you Thumbs Up Pete
Post #392134 18th Jun 2016 11:00am
Jacckk
2010 Range Rover Autobiography 5.0 SC V8 Mariana Black
The LCM from the later models works fine in the early cars. I got one for mine and turned off some of the light checking settings which means you don't need resistors or anything else to fit the 2012 lights.
The correct LCM will say LCM IV or LCM 4B on the sticker. The X5 LCMs also seem to work if you disable some of the check control messages that the RR doesn't have.
Post #392168 18th Jun 2016 3:50pm
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
You still need the resisters even with the later LCM ECU, if you don't your rear lights are massively too bright and it looks like your driving round with the rear fog lights all the time
Matt Current
2012 Range Rover 5.0L SC Ultimate Edition
2012 Range Rover 4.4L TDV8 Autobiography
2010 Range Rover 3.6L TDV8 Autobiography
2003 Range Rover 4.4L V8 Bespoke Vehicle
Inventor of the retro fit paddle shift and many other modifications.
Creator of the custom 2010+ RR MK4 splash screen.
Creator of the Range Rover CarPC and lots more!
Founder of Range Rover Owner
rangeroverowner.com | Facebook.com/RangeRoverOwner | Latest Videos ➞ YouTube.com/RangeRoverOwner
Post #392195 18th Jun 2016 10:17pm
jam220
United States 2007 Range Rover HSE 4.4 V8 Bonatti Grey
Hi how are you so Im kinda sort of hijacking the thread and see you are in Durham. Question did you do the facelift on your truck? If so I am in the middle of doing it on a 07 and have a few questions. I have not bought any of the resistors for either front and left but I am talking with Jr eclectic about theirs. What year is your truck and what year did the LCM that you used came from. Thank you
Post #393878 30th Jun 2016 5:49pm
