![]() | Home > Technical (L322) > TD6 Normal Behaviour? Cruise Control |
Stacker Member Since: 04 May 2016 Location: Theale, Reading Posts: 481 ![]() ![]() ![]() |
If I set my cruise control to say 50, on a slight uphill incline every few seconds when the speed drops slightly, it goes from 1800ish to 3000rpm, and revs right up until it hits the right speed again, but feels very erratic at times
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35808 ![]() ![]() |
it does rev to get the vehicle up to selected cruise speed but not sure it should be as harsh as you're experiencing.. ... - .- -.
Thanks for the reply Stan. I'll try and get a video later on my trusty go pro!
At 50 you are in the muddly mix of 4th gear and 5th gear, along with torque convertor lock up territory.
Thanks for the reply there Joe.
I'm not surprised it annoyed you!
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
As Joe said your right in the middle of all the bad bits for the gearbox, at 50 it's right at the upper limit of the 10% slippage to stop torque vibration, and the slightest touch of the throttle will disengage the TCC (lock up) and allow the engine to rev freely...... try it at 55.... it will be in total lock up at that speed and less likely to rev it's bits off |
At the risk of upsetting the 60+ brigade, I thought I would give this a try on the way home, on a 5 mile stretch of A road with plenty of ups and downs, a couple of steeper ones too.
Interesting!
cowman Member Since: 24 Jul 2013 Location: United Kingdom Posts: 186 ![]() ![]() ![]() |
my td6 has started doing this but doesnt rev more than a couple of hundred ,it does it when not in cc ,have i got a prob with it it says in the hand book press button to switch on light on dash comes on press again to suspend,then press and hold until light goes out to switch of. the prob i have is when i hold to switch off the light does not go out,has anybody got any ideas to what is wrong,thanks for a great forum. |
Are you talking about the cruise contol?
It's all to do with the speed that your travelling at and the power available from the engine, if the ECU's determine that the engine doesn't have enough power to maintain the speed set it will disengage the torque converter lock up, which adds power to a rough factor of 1.9 x, and if the car is still loosing speed it will select a lower gear.
you should press the 1-0 button to get the light on the dash, then at the desired speed press the +, to suspend the CC press 1-0 once and the speedo symbol to resume..... to cancel you need to press the 1-0 twice if your cruising and once if your not cruising....... there is no press and hold ![]() Inventor of the 'Guide-o-Matic automatic wheel alignment tool' Former long term L322 owner, Up/Down graded to a Classic Tractor! |
