![]() | Home > Technical (L322) > P2105 throttle body |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35808 ![]() ![]() |
any help?
FleXzoR Member Since: 28 Jan 2013 Location: Bruges Posts: 44 ![]() ![]() ![]() |
Thanks for the information.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8755 ![]() ![]() ![]() |
If you forced the throttle body open when you cleaned it then this can seriously damage the internals.... Pete
I forced indeed the throttle body for cleaning.. Although did not had to use alot of force... MY2008 Buckingham Blue Supercharged - gone
Very delicate item, not designed to be opened against the motor, worth seeing if there are live values available to monitor it working... Pete
Strange i do not have any other problems despite the problem i mentioned. In normal drive nothing noticable. Only a bit judder at idle sometimes.. Changes spark plugs allready MY2008 Buckingham Blue Supercharged - gone
