![]() | Home > Technical (L322) > 2010 NSR Driveshaft stuck in hub |
There is a special tool from LR. Bolts on the hub and winds out the shaft. Amazing bit of kit! |
| Mattwales Member Since: 12 Oct 2022 Location: S Wales Posts: 4
I did try using the slide hammer in reverse essentially to achieve the same thing.
I’ve never not gotten one out using that tool sir… |
