Home > Maintenance & Mods (L322) > Dash and running board question
Danwilderspin
firstly the dash nice I've had it off has about an 8mm gap above the glovebox even though all screws are in - any ideas?
Next my running boards don't look clipped together properly is there a way to do this?
Post #395029 8th Jul 2016 1:26pm
Does the front of the dash move if you try to lift it, it slides back on and the screws stop it moving, but you can miss the clips that locate it and get the screws in, if you can lift the front edge at all then it needs refitting....
Haven't a clue on the side steps, probably rust under there pushing them apart, they do seem to rust well.... Pete
-Click here for Thread-
Post #395085 8th Jul 2016 7:04pm
My side steps are a lot worse than that! MOT on Monday so will have to do some fixing to avoid "dangerous bodywork"! Laughing .
Post #395101 8th Jul 2016 8:19pm
paulmoran2
England 2013 Range Rover Vogue SDV8 Mariana Black
If its a LR factory / dealer fit step....The side steps are in three pieces. The metal frame that hangs off the car, the rubber step and the lower silver plastic trim.
The rubber step has rubber lugs protruding downwards ( towards the floor) that engage into similarly sized slot shaped holes in the metal frame. If the rubber has lifted, you may need to push( or hammer ) the rubber step downwards so the lugs go back into the slotted holes. You should be able to feel the holes if you put you hand under the step.
Be careful not to damage the delicate plastic silver trim as theyre £64 each to replace. The trim can be removed before pushing ( or rubber malleting) the rubber back down into place by undoing the dozen or so screws along its length. GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
HAVE 1999 Discovery 2 GS 4.0 V8 - Silver - Off Road Toy
GONE 2013 L405 4.4 SDV8 Vogue. Black with Silver roofline and 22" s
HAVE 2015 Jaguar XF.
Post #395102 8th Jul 2016 8:24pm
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
There could be mud/debris under the rubber which will peel back to check, or the small screws that hold that piece of plastic trim on are missing or corroded. Or as above it might just be kna Censored ed.
Post #395104 8th Jul 2016 8:26pm
Most likely the small ferrous screws have corroded and fallen away Wink .
Post #395130 8th Jul 2016 10:29pm
LROMAD
United Kingdom 2008 Range Rover Vogue TDV8 Stornoway Grey
Hi Paulmoran2 , sorry for hijacking,but do you know where I can get the plastic trim you mentioned ,from ?? Are they MD parts ? £64 a bit steep ! Rolling Eyes thanks Ray .
Post #395155 9th Jul 2016 6:06am
paulmoran2
LROMAD...if I'm honest I didn't shop around as always get a good deal from Dan at Duckworth ( Forum sponsor) but they may be available elsewhere?. paul GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
Post #395169 9th Jul 2016 8:35am
Had a good look at side steps this morning, and performed a bodge repair (they will be coming off soon for some body work repairs, so will probably replace, so this was to stop them falling off altogether!)
The silver outer trim is held on all along with self tappers into a plastic fixing which pushes up into the outer rail. The plastic fixing is pushed into a small L bracket which is spot welded onto the main rail. In my case all these spot welds have rusted away. If I could have been arsed I would have removed the trim, drilled out and refitted the L brackets for a clean finish.
However I just drilled three holes through the silver trim into the main rail and fixed with 2in domed self tappers (sorry purists) .
Post #395198 9th Jul 2016 12:53pm
