Home > In Car Electronics (L322) > Range Rover TDV8 2007 SatNavUnit & Update
vecchifilm
Italy 2007 Range Rover Vogue SE TDV8 Alveston Red
Hi, i have some questions:
1- my dvd gps unit is very very hot. burning even without DVD (original or copy) added.
i use a copy because of the heat the disc flexes and line.
is my unit broken ??
2- Is possible to change my dvd unit with a ssd disk ?
3- Is possible change original monitor unit with a 2 din android ?
Thanks
Post #395067 8th Jul 2016 4:59pm
1..how hot is hot?
2..nope
3..nope ... - .- -.
Post #395072 8th Jul 2016 5:59pm
vecchifilm
very very very hot !!!!
the phone module isn't too hot. just the dvd unit YIB500070
ps. thanks
Post #395079 8th Jul 2016 6:39pm
Is it getting hotter - it was only very very hot in the original post Whistle
It sounds like theres something wrong with it - it may get warm but not hot.
Post #395081 8th Jul 2016 6:51pm
vecchifilm
show me the power connector? I try to disconnect it for a while 'and then hang up.
I can let it without power? blocks other functions?
I could leave it unplugged and get a garmin
Post #395095 8th Jul 2016 7:31pm
vecchifilm
rear of unit
http://www.fullfatrr.com/gallery/albums/us...b___57.JPG
Post #395096 8th Jul 2016 7:32pm
Is there a separate fuse for it ?
Post #395105 8th Jul 2016 8:28pm
vecchifilm
For fuse i can to see....
But it's possible to disconnect the gps dvd unit ?
If so i buy a tomtom navigator and my problem is solved !!
Post #395209 9th Jul 2016 1:13pm
It should be possible to disconnect the dvd and then bridge the MOST fibre optic cable using the bic biro method to take it out of the loop. I think. There is nothing that can't be fixed with a hammer😜😜
Post #395255 9th Jul 2016 4:56pm
i would disconnect power first to see if theres a MOST throughput, if not then as above.. ... - .- -.
Post #395257 9th Jul 2016 5:00pm
Weegie
Or use a fibre optic loop:
eg. http://www.ebay.co.uk/sch/i.html?_nkw=fibe...noapp=true John
GAP iiD BT-Sold
Post #395261 9th Jul 2016 5:04pm
Busa1400
England 2007 Range Rover Vogue SE TDV8 Santorini Black
There is no fibre optic loop on DVD it is just fibre in, not out, it is a spur. 2011 Range Rover Vogue SE
Post #396570 18th Jul 2016 9:33am
