![]() | Home > Technical (L322) > park heat / cooling key fob |
Fleagle_UK Member Since: 20 Mar 2013 Location: Cheshire Posts: 409 ![]() ![]() ![]() |
Due to me being an idiot |
Yeah my current one is (was) a t91.
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1671 ![]() ![]() ![]() |
I thought they actually need programming to the receiver not just pairing like a BT phone etc? Dealer job? 405 AB exec seats Baltic and Cirrus
Giantlandyman Member Since: 25 Nov 2015 Location: Essex Posts: 800 ![]() ![]() ![]() |
When they paired a new fob for me, it took the sum total of about six seconds, no tools and that's including the walk from the boot to the cabin so I don't think there's a great deal to it.
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3270 ![]() ![]() ![]() |
The T90 and T91 definitely don't need pairing by a dealer. How to is in Wiki. Don't know if the L405 is different. John
I had to re sync/pair my t91 fob last year as for some reason it lost connection.
Brightondefender Member Since: 29 Jan 2013 Location: East Sussex Posts: 36 ![]() |
I have the pre-heat function but I didnt realise this can be used also as a 'pre-cool'? Or have I misunderstood? |
Not sure what MY you have but when you press the on button on your remote (or program through the menu on the touch screen) the HeVAC system checks what the cuttent outside air temperature is. if i recall correctly, if OAT is 13 or less then the FBH and blowers kicks in to heat the car ( assuming fuel level not in red and the battery management system doesnt report low battery) if greater than 13 celcius then the fans blow to bring in fresh air to help cool the interior. Note it doesnt use air con to do this just fresh air. Either way it runs for about 15 mins but be aware many owners have had problems with this.
Thanks Fleagle |
Yep - should be same as mine then. I don't recall park cooling (venting) as being an optional "add on" to park heating for MY12 cars. If you have one then you have both......I think. |
just to close the loop - sadly the l405 remote fob won't pair with the T91 of the L322 despite both being webasto units. Shame.
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
I have one and would be willing to swap it for your 405 unit |
