![]() | Home > Technical (L322) > Battery reset |
If you have a system that needs a reset, pull it's fuse for 10 minutes..... Land Rover Addict
You can fry your nav computer doing this, especially when you reconnect the battery, if you miss the terminal and it turns on and off in quick succession etc.
David Member Since: 15 Oct 2010 Location: Murcia Posts: 301 ![]() ![]() ![]() |
Hi Dan
On the 4.2 S/C "R" Jaguar you have to input a specific code after battery replacement (although there is another way |
You should be able to get the part number from microcat... Isn't it an Alpine unit? I believe the DVD unit in my car is different to yours though. ![]() |
See halfords are doing a battery fitting charge for £4.99p ........ could save a lot of hassle ...... |
Mick do you have a larger version of your Avatar please as I am mesmerised ![]() |
if i could get microcat to work proply i would !!! |
