the actual dashtop with the stitched leather is a whole panel, that is taken off for say, work on the radio system. you can find a how to on here. but it involves removing the black vent panels at either end, and then about 10 bolts that hold it down, then, you remove the dashtop. you might find that the sort of 'left hand panel' to the side of the radio, has this piece still somewhere in that area, -what i mean is, it might have fallen off, or bent back etc. i have the ealier model. the trim piece that holds the airbag, is removable, and maybe that is where you need to be looking. it only takes about 20 mins to remove. you will need some torx type allen keys.
