![]() | Home > Technical (L322) > Front flap fitting Q's? |
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
That looks so wrong. You should not need to cut the liner |
Thats the way mine look and it was a LR dealership that fitted them ........... |
DavidP Member Since: 20 Oct 2010 Location: BN Posts: 425 ![]() ![]() ![]() |
if this is what they look like then neither i or a dealer will be fitting...... |
Fox Member Since: 02 Apr 2010 Location: Essex Posts: 2313 ![]() ![]() |
Surely doing that means the crud doesn't go on the outside of your bodywork, but instead can go up inside? |
I fitted LR units without cutting but you do have to drill and remove Side intakes to fit correctly. All in the instructions. |
skippy Member Since: 09 Jan 2010 Location: Sheffield Posts: 41 ![]() ![]() ![]() |
mines the same too looks like somebody has taken a axe to them |
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 ![]() ![]() |
I will be requesting new liners, as butchery wasn't required nor requested. |
Booked into the dealer wed, new inner arch. And a few other gremlins, drivers heated seat base not getting hot, tyre valve broken and a yoky as a spare in place of the pirellis. App the sales manager only authorised a budget tyre. Yeah right, after the money I've just spent. |
Time to find a proper dealer rather than cowboys pretending to be one? |
In fairness the service manager was spot on this morning. Only owned it since friday. Second hand buys are not a perfect experience but the dealer will get the hang of it. |
