![]() | Home > Technical (L322) > Air Suspension |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8752 ![]() ![]() ![]() |
Should really be changed in pairs as the shock absorber is integral and it is not good practice to just change one...
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1423 ![]() ![]() ![]() |
Haylands will know a lot more about this than I do, but when my 2004 4.4 burst an airbag the dealer just changed that one (this when the car was maybe 7 yrs old) and there were no problems with any of the bags during the remaining 2 1/2 yrs or so I had it. Only Range Rovers since 1988 |
It's good engineering practice to change them in pairs, no matter what people say about gas filled shocks being OK... they will wear, they are a consumable and not designed to last the life of the car so even a one year old one will have a reduced effect under emergency braking, even if one side dips slightly more than the other this can effect braking... personally I think it's worth the cost to change the pair...
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2286 ![]() ![]() ![]() |
I had a similar situation and replaced both not because of the bag but because of the shocks as has been said its good engineering to replace in pairs if for no other reason than to keep the suspension properly balanced. |
