![]() | Home > Maintenance & Mods (L322) > Brake upgrade?? |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
How many miles have you done?
EmiratesA380 Member Since: 14 Jan 2015 Location: england Posts: 361 ![]() ![]() ![]() |
Hey Fella - Are you sure the "horrendous Squeaking Noise" is not coming from the rear shoes - I expect it is. As many of you will know the rear disc brakes are whats visible - but inside the rear axles are the break shoes themselves - THESE MUST BE TAKEN OFF & CLEANED AT LEAST EVERY SERVICE ( very very easy to do ) - they build up with RUST that pits solid and then makes the so called: horrendous Squeaking Noise. I would check this one first - as regards to your question - theirs no comparison to using OE FFRR discs - LR have designed the whole car with top quality parts - after all its their "Flag Ship" Our 2 FFRR are 12 year builds and are on their 2nd set of front dics - last set mileage was around 43k & 28K - and they were only half worn I would expect a FFRR 4.4 variant would achieve around 50k before a change was due ( and this is with only a partial lip on the discs - NOT a 20" Grove on Lip ! - as I have seen on some cars ( they say when buying a used car forget about the body look at the discs. Having said that may be the 4.4 TDV8 has more Torque at braking the the petrol variant - but if you plan the road ahead and look out for any Muppet's on roundabouts you should be OK As Clarkson once said - "if in doubt ...... pedal to the metal and let no man stand in the way" Hope this is helpful . |
