Home > In Car Electronics (L322) > Dash cluster reset
Chasazim
Australia 2004 Range Rover Vogue 4.4 V8 Epsom Green
Dash cluster reset
Hello again, my ff is keeping me busy, my fault. Since the problem with the fuel guage not reading correct I thought I would try the reset procedure my problem is it will not do as it,s told Shocked when I go through the steps and after I select test19 on the right butten then press the left I get LOCK ON and then it counts up but does nothing what have I done wrong and how do I fix it Censored Big Cry
Post #399260 5th Aug 2016 6:20am
mjdronfield
Sounds like the tests are locked I think, hence the lock on message? You have to unlock the tests..... It's years since I did this on one of my BMWs so forgive the old memory!
Bit of BMW related info here.... Should be similar...
http://www.bimmerfest.com/forums/showthread.php?t=722428 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #399331 5th Aug 2016 6:44pm
