![]() | Home > Maintenance & Mods (L322) > HVAC has a mind of its own! |
SteMY06HSE Member Since: 23 Jun 2016 Location: Doha Posts: 63 ![]() ![]() ![]() |
Ok first serious post after getting my FFRR in June...
What happens if you just set to auto, air con on, dials at 22, with thumbwheel on one blue?
If I set the system to fully AUTO, then the fan goes full speed and even after driving for 10 minutes the speed never decreases.
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3271 ![]() ![]() ![]() |
I wonder if it isn't just trying to reduce the interior temperature? Pretty hot where you are so, at start up, the interior temperature will be high.
With the settings I indicated earlier on a warm day here (25 degrees) the car will take a good 20 minutes on full cooling before it gets the internal temperature to where it wants, then starts to slow down a bit (often this can be too soon when driving West into the sun!)
Thanks for the info... I will monitor it for a while and see what happens on a long drive... taking her off road in a couple of weeks to the desert now I have had the mechanical niggles fixed so that will be a long run.
Starberg Member Since: 08 Jan 2015 Location: Karlskrona Posts: 70 ![]() ![]() ![]() |
Had the same problem. Turned out to be the controlpanel in the dash as you suggested! L322 Vogue 2003 |
Further testing and diagnostics this morning... Was out early taking my boy to his summer camp before work, outside temp 38 degrees. Car parked under the car shelter overnight so it was not baking inside like usual. Driven for about an hour with internal temp on 22 and full auto. Fans running flat out all the time. I even left the car running when I dropped him off to maintain the chilling. No difference at all so I am thinking/starting to convince myself that its the control unit as Starberg has had similar issues.
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3983 ![]() ![]() ![]() |
It's not just the compressor that may be bigger all the heat transfer surfaces ie the evaporator and condenser surfaces will be too. I still think it will be at the upper end of its performance at the temperatures you are experiencing.
My fans would not slow down here when I first brought the car over from the UK , it just needed a re gassing . The first place I took it to to have the gas put back after it had been taken out for shipping hadn't turned the rear HEVAC on so it didn't receive a full fill . It's also quite common to have micro holes somewhere in the system so after a long while you just get too low .A properly functioning Full Fat air con will cope well with 40+ because from memory it's something like an 11kw or 12kw system , plenty good enough . 2008 MY Supercharged
OK... so the plot thickens... last week it was very hot and humid here in Doha, and after a midday meeting with work in town, driving back to the office was not nice. A/C blowing mildly cool if that. Took it to the local Land Rover Dealer on Saturday who checked the gas as a first port of call.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8808 ![]() ![]() ![]() |
Very unlikely to be the evaporator, they don't tend to leak... how do they know it is that....??
Thanks Haylands, I will give the condenser a good visual going over and see if I can spot anything along with the other pipe work and connections.
For your parts use Duckworth Dan from this site , I use him whenever I can due to a similar pricing policy to yours here in WA. Most prices are between a third to half local charges and he can ship to me in about four days . 2008 MY Supercharged
